Help required
Adam270
12/2/18
Redcar northeast England
Hi I am after some help after today my dad and mam saw my arf sub and could not believe it was a rep and now my dad wants a omega James Bond edition and my mam wants a Rolex so could somebody put me in the right direction of which are the best out of the box omega and best Rolex ladies thanks .
i know I will probably get shot down for this for not searching previous posts. But it took me months of searching for me to buy a arf sub so if anybody can help me out it would be great fully recieved thank you in advance and I will start doing some reading in the mean time thanks
Dan2018
167
50
U.K.
VSF is noted to be good: the dial isn’t the best thought, perhaps it’s worth holding on for now as the movement is fine so they can only improve that. The Cartier recommendation is solid, it’s a great rep.
Adam270
12/2/18
Are you saying that the movement isn't very good and that needs improving or are you saying that the dial requires improvement thanks
Ams55557
633
350
While it has flaws, I don’t know if a James Bond omega that it currently easily available.
The other sea masters are pretty solid but they may not be from a specific James Bond film.
Dan2018
167
50
U.K.
It’s the dial mate that needs improving. The movement is a new movement and not quite tried and tested yet, but the consensus on it is it’s a good quality movement.
palaufreak
833
592
Your mom could use an ARF 36mm datejust. It's the best Rolex datejust ootb.
Sent from my SM-G930F using Tapatalk
chocolito
1,661
861
My mam only has small wrists so is there a good 28 MM Rolex available
thanks for all the help
In short no . If you want a small watch still go for a Cartier Ballon Bleu V6 ( V6F) factory do a 28mm version with a Ronda Quartz . I take it being a female your mom won't want a automatic watch LOL. The 42mm version of the watch is considered a NWBIG Super Rep , the 28mm isn't far behind . Currently listed as joining their big brother but need more feedback .Also miles cheaper than the version you have previously been directed to above by Ams . You could practically buy both watches for the price of that watch . Any TD will be able to get for you . Latest V2 version MOP dial $198 with diamond bezel (lol)$218 .
If want a 28mm Datejust ! I think last time there was a discussion on here the BP factory versions were deemed the best with a clone ETA .
The VSF Spectre 8400 Ams has linked is currently the best OOTB version .
