- 19/4/19
- 27
- 10
- 3
My movement has come loose in the case. Has anyone had the same thing happen with theirs? I took the back off and it's not the case clamps. It's the whole movement holder (or whatever it's called) that is moving in the case. You can see the gap for the crown screw. The whole inside is moving including the piece with the opening for the crown screw. If it wasn't for the crown the movement and it's case would fall out.
I worry about it because you can see the dial and everything moving when you wind it and sometimes the crown binds a bit when screwing it down. Once the crown is screwed down things are solidly in place.
Can this be fixed and if so, how? I'd like to get it done the right way. I'm pretty handy myself and if it's too much for me I'm willing to get a skilled person to work on it. I just don't see how it's supposed to be held in place moreso than it is.
