- 14/6/18
- 450
- 104
- 43
Would there be any interest from Gen Speedy owners/modders in buying replica dials of popular LE models (45th Apollo 13 Anniv Silver Snoopy for example).
I’m talking with Angus from pure time to see if we can get one of our rep factories to make a batch of replica dials that will fit the gen movement/case. They already make the Apollo 11 45th, Apollo 13 45th, Speedy Tuesday, etc. for the ST19 in pretty good quality (though with obvious wrong measurements) so it shouldn’t be too difficult to get them to port over some of that know how / experience into a dial fit for a gen speedy.
I modded my first Gen Speedy with a Mitsukoshi Dial and Handset from swisslimitededitions but the pricing on these in the aftermarket has gone insane (2 or 3 years ago I bought it for like 400 gbp, now they’re 900gbp for dial alone). The process is actually quite easy for any halfway competent watchsmith so I would assume the market for this in our community would be quite large.
Angus is indicating that the minimum order quantity from the dial factories is probably like 500 so we’re definitely going to need quite a healthy showing from our community here to meet this order. Unfortunately that probably means we need to start with one variant first as I doubt the factories would consider different dial variants put together for an order of 500 kosher.
I haven’t discussed with Angus yet but I assume the handset is an area we should probably stick with Omega service parts at least at first given the manufacturing of the hands is far more sensitive than the dial (need to get fitment right for all six hands compared to basically no foreseeable complications with a dial)
In my mind the top candidates at the moment are the snoopy dials
45th Anniv Apollo 13 (Silver Snoopy)
-Black handset from omega readily available
-Silver Snoopy ST19 replica already pretty good quality (aside from dimensions so should be an “easy” port)
-This dial has not been available as new omega service part in the aftermarket
Eye’s on the Stars Snoopy Dial (Basically a regular Speedy dial with a snoopy cartoon sub dial)
-can reuse regular speedmaster hands so it’s a straight dial swap
-has been and is currently available in secondary market as new omega service part but at 1800gbp
These maybe possible down the line once we’ve proved to ourselves and the factories we can sustain enough demand to justify the change in tooling/development
45th Anniv Apollo 11
-This will require a replica handset as they’re finished in “Sedna Gold”, relative complexity is higher and genuine service parts for this are unavailable
-Dial is textured which means it’s more costly to produce
Mitsukoshi Panda Dial
-Applied Metal Indices makes price a bit higher compared to printed dials
-is currently available as new omega service part though at nearly 1200 gbp handset+dial
The New 50th Anniv Apollo 13 Silver Snoopy (the silver + blue one that just came out)
-textured dial and custom hands are more complicated
Apollo Soyuz Meteorite dial
-handset can be sourced Omega New Service Parts but applied indices & meteorite finish are more complex
50th Anniv Apollo 11
-Texture + hands issue again
Let me know what you guys think.
