- 15/10/17
- 2,058
- 829
- 113
The description says the thickness is only 14mm. Is that correct and if so why can't they get the other ones that thin?
It's the same Lemania .. Well venus 75 clone as the others
Why they keep realisng those reps with wrong subdials spacing but can't invest for a good clone movement? :frusty:
May someone explain it to me with pictures?? Is it such a big flaw? Those colors look so great! Thank you!
Subdials at 3-6-9 should be closer to the center, as all hour indexes should be the same lenght. In the rep subdials are more spaced out due to the movement used.
Still no factory freezed the 6 o'clock 24 hrs subdial... That is a BIG tell - For me I hate it even more than the subdials spacing.
Sent from my HUAWEI VNS-L31 using Tapatalk
The thickness of this watch scares me. Let alone the non functioning chrono and sundial spacing.
Do you know the gen thickness?
What‘s the matter with the chrono? From the descriptions in TD webshops, I understand, that the functions are working like gen.
Thanks in advance
