Hi, I´m Rainer, I am new here. Got a VSF Seamster Spectre which is defected. Need help to find a watchsmith who might be able to repair it.
The problem, that my local watchsmith detected is:
„The movement was almost completely dismantled to find the fault.
A change wheel in the pointer mechanism is defective. Its teeth are badly worn and partly bent.
The wheel engages in the gear train and blocks it. It is responsible for the transmission to the pointer mechanism.
May there be a movement that could fit into the case to make the watch be useable again?
Cheers! Rainer
Cheers! Rainer
