Need to have it waterproofed and tested,(want to swim with it and go from outside cold temps to warm inside temps when skiing), fix click that occurs when I press down on the sides of the bezel, adjust cyclops or replace, replace with a better bezel insert and maybe dial depending on cost (preferably gen that doesn't cost $750+), clean and calibrate movement and basically do anything else that you think needs to be done. Please feel free to PM me if you don't want to respond here. I'm in the U.S. and prefer a modder in the U.S. Thanks!
