Bell Ross Quartz Chrono BR 01-94 PLEASE HELP
horologie_unitas
Put Some Respect On My Name
3/12/06
5,148
Hello to everyone,
i have the watch mentioned above. Battery needs to be replaced, i understand, the little screw in thze back needs to be removed, in order to remove the crown. removed the screw, but the crwn with stem will not come out !! any help, ideas, greatly appreciated !
Oascom
Watchmaker / Modder
Vendor (Watch Repair)
4,373
4,955
WWW.WATCHMAKERUSA.COM
You need to press the button that is inside to release the crown. I just serviced similar watch. Just mechanical.
horologie_unitas
3/12/06
5,148
thank you, i tried that, with a needle, the stem will not come out. in which position does the crown has to be when pushing the pin in ? thanks for your efforts helping
