Rotor noise fix EU / (NL) MIYOTA 9015
Kvdnwh86
19/12/17
55
15
Dear members,
I recently bought An AP ROO (JF) this is my first MIYOTA watch, I did read about the rotor sound but also read that it can be fixed easily, so I am looking for someone who can “fix” this and turn it in to a quit watch?
Looking for someone in the EU, I’m from the Netherlands.
Please contact me if anyone can help me solve this issue.
Verzonden vanaf mijn iPhone met Tapatalk
VIV54
688
392
yes it can be fixed but don't expect it to be like a bi directional rotor. Miyota 9015 are loud and you have to accept them the way they are, there will always be a direction where the rotor spins freely and generates friction noise. :( If you slow it down too much you will lose all the winding efficiency.
chocolito
1,661
860
Needs a heavier rotor fitting . This will make the one way rotor much quieter.
chocolito
1,661
860
Is this available with all engravings?
Sent from the RWI App
No ! You could try the mobius oil to the central pin method . However I don't think this takes the noise away but does take it down a little . When buying a watch with a Miyota 9015 rotor noise is something you should factor it in . The rotor winds one way but spins freely the other which gives you the Zebedee from Magic Roundabout noise .
Sunsurfer
283
396
I took of the rotor of a 9015 and put on a it drop of mobius D5 oil.
Now all efficiency is gone.
Any idea how to clean the bearing? Wd40?
Sunsurfer
283
396
any suggestion how to clean the bearing of the rotor from mobius D5?
32,738
58,862
Submerge it in naptha or lighter fluid a small jar. Agitate it a few minutes. Best done in an ultrasonic machine, put the jar in water in the nachine. The unit will agitate the naptha inside the jar. Alternatively you can agitate manually with a watch dust blower.
Use a dust blower to dry it off, then repeat process using isopropyl alcohol. When done, one drop of Moebius 9010 is the correct lubricant to use.
Reactions: Sunsurfer
Sunsurfer
283
396
Thanks for your help. My watch works great again :)
ich put the rotor in a bath of isopropyl 70% and turned the inner part with the three holes with a toothpick one minute.
Then I let it sock and turned the inner part with a toothpick all 10-20 minutes a couple of times.
After three hours i took the rotor out and dryed the bearing with a dustblower. A few drops came out.
I let everything dry out over night, then I reassembled.
until now I did not put new oil on it.
now the power reserve i back again :)
the rotor is louder again but not as load as from stock. Maybe i will put moebius 9010 on it one day.
KJ2020 thanks for the help ! :)
Reactions: KJ2020
