YLF Master Ultra Thin Moon
EunosMX5
160
23
Any key differences so far? Still 9015 based as far as I can tell, guess we need to wait for more pictures.
LHD_Kid
6/4/20
91
65
Would also be interesting to see the strap and clasp. This is the single biggest problem with the VF version (apart from moonphase)
Do you know if the YLF is true moonphase or day/night?
JvanniMan123
DO NOT TRADE WITH ME
19/2/19
873
89
Just got the same message from my local dealer. He says its functioning moon phase but it will be more expesnive then GF and ZF
jh9596
Horology Curious
21/10/19
12
I have one of these on order. I'm told I'll have QC pics within the week - will post them here when I do!
jh9596
Horology Curious
21/10/19
12
I just ordered one from JTime and paid $358 - ZFs are >$400 anywhere I've seen them!
JvanniMan123
19/2/19
873
89
Weird , as far as I am aware there are two versions. Personally I think I still prefer the ZF , I had it and absolutely LOVED it
jh9596
Horology Curious
21/10/19
12
That is weird, Li never mentioned. Decided to gamble on the YLF as the very few pics I've seen of the movement look like a good clone - jury is out on the finishing. Can't go wrong with the ZF though, I have a ZF PP Calatrava and the finish is phenomenal.
JvanniMan123
19/2/19
873
89
I would not call it a clone, its a miyota inside which well I hate ( Im not a big fan of miyotas)
jh9596
Horology Curious
21/10/19
12
The YLF looks almost identical to the JLC 925/1 from the outside, whereas the ZF is noticeably pretty different. But yeah I'm assuming it's still just a 9015 on the inside?
XLR8R
692
354
Decoration plate looks acceptable but its noy even close to the genuine counterparts finishing on movememnt
Jack Liu
Horology Curious
22/1/20
23
44
13
some pics of the moonphase model
通过我的 EML-AL00 上的 Tapatalk发言
sgt.njoy
M2M Camper
1,115
780
Illinois
This is direct translation from google.
Master series, the only version consistent with the authentic
About the movement:
Automatic winding system: YL version of the movement is a two-way winding, while other versions of the market are single-up winding
Automatic winding noise: The YL version has only a slight chain sound (same as the original product), while other versions in the market are the noise generated by the automatic rotor rotating the friction bottom cover and the movement deck
The structure of the movement: the YL version of the movement is demolished by disassembling the genuine movement of the same model, and the structure is basically the same. The matching of the movement parts is more than 95%, while the other versions of the movement are modified with the Japanese 9015 movement. Come, the structure is different
Movement shock absorber: The Yl version of the movement shock absorber is the same as the original KIF shock absorber, while the other versions on the market are the original ecological shock absorbers of the Japanese 9015 movement.
After repeated testing ~ the stability is comparable to the original!
LHD_Kid
6/4/20
91
65
Looks reasonable, but big flaws like alignment of 6 marker would put me off...
