- 16/2/16
- 1,793
- 916
- 113
To avoid some scammers to do profit by selling Jf pin buckles on ebay, C24, Trf... This is the comparison with JF and Audemars pin buckles.
As for a strap, case, and global finish, the genuine Audemars pin buckles are perfectly executed. Even if JF did a very good job on these three pin buckles, there is no doubt that the AP factory is in a completely other level.
More than words, picts :
Gen at the bottom :
Gen 24mm Ti at the top and at the right. You can noticed the gen 24Ti isn't as dark as the JF Ti buckle.
Gen 24mm diver / ROO 44mm buckle at the top
Gen 20mm at the top and at the right
Gen buckles at the right
To finish, this is the difference when the pin buckles are mounted on a strap.
Jf 20mm pin buckle when the rubber is closed
Gen 20mm perfectly closed without any gap/hole
Gen at the bottom :
